Home> Ürünler> Anahtarlar> Access Switches>
RG-S2910-24GT4XS-UP-H(V3.0)
● Power Redundancy Support
Daha fazla+
HPoE
HPoE
Simple Deployment
Shortened construction period
Reduced costs
Simple Deployment
Secure and Reliable
Easy O&M
RG-S2910-24GT4SFP-UP-H
RG-S2910-10GT2SFP-UP-H
Up to 256Gbps
Up to 256Gbps
Up to 256Gbps
42Mpps/96Mpps
Up to 96Mpps
Up to 18Mpps
16K
64 (IPv4/IPv6)
In: 1500
Out: 500
In: 1500
Out: 500
In: 750
Out: N/A
Basic QinQ, Flexible QinQ
OpenFlow
VSU Stack Members
Up to 9 stack members
VSL
Layer 3 Features
ARP, IPv4/v6
IPv4 Routing Protocols
Static Routing, RIPng, OSPFv3
GR for RIP
GR for RIP
GR for RIP
Dimensions (W x D x H) (mm)
440×260×44
440×260×44
340×260×44
361712 hours
388055 hours
408710 hours
Common Mode 6KV
Frequency: 50Hz to 60Hz
<460W
<460W
<630W
PoE Power Consumption
Storage humidity: 5% to 95%RH
PoC Guide
Release Note
