RG-CS83-12GT4XS-P Anahtarlar - 1
RG-CS83-12GT4XS-P Anahtarlar - 2
RG-CS83-12GT4XS-P Anahtarlar - 3
RG-CS83-12GT4XS-P Anahtarlar - 4
RG-CS83-12GT4XS-P Anahtarlar - 5
RG-CS83-12GT4XS-P Anahtarlar - 6
RG-CS83-12GT4XS-P Anahtarlar - 7
RG-CS83-12GT4XS-P Anahtarlar - 8
RG-CS83-12GT4XS-P Anahtarlar - 9
RG-CS83-12GT4XS-P Anahtarlar - 10
RG-CS83-12GT4XS-P 12-Port 1GE RJ45 Layer 3 Managed Access Switch with PoE+, 4-Port 10GE Uplink
RG-CS83-12GT4XS-P
12 x 10/100/1000BASE-T ports and four 1GE/10GE SFP+ ports for flexible networking
Flexible installation
Silence
Carrier-class Reliability
Make Your Business Easy
Flexible Management Modes
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Fixed service ports
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
78 Mpps
104 Gbps
1.5 MB
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
3.25 kg (7.17 lbs)
3.3 kg (7.28 lbs)
3.4 kg (7.50 lbs)
4.0 kg (8.82 lbs)
4.10 kg
(9.04 lbs)
4.10 kg
(9.04 lbs)
4.18 kg
(9.22 lbs)
4.25 kg
(9.37 lbs)
4.90 kg
(10.80 lbs)
RG-CS83-24GT4XS
RG-CS83-48GT4XS
Built-in power supply: 25 W
Built-in power supply: 40 W
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Built-in power supply: 409 W
35 W (non-PoE)
405 W (PoE full load)
35 W (non-PoE)
52 W (non-PoE)
460 W (PoE full load)
The maximum power is 405 W
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Fanless, quiet, < 20 dB
27℃ (80.6°F): 32 dB
27℃ (80.6°F): 35 dB
27℃ (80.6°F): 32 dB
27℃ (80.6°F): 35 dB
Communication port: 10 kV
RG-CS83 Series
Communication standard
RG-CS83 Series
Non blocking
SPAN, RSPAN
Interface priority
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
How is loop detection realized?
This series adopts the Rapid Link Detection Protocol (RLDP) – a link detection protocol independently developed by Ruijie Networks for rapid detection of Ethernet link failures.
Most Ethernet link detection mechanisms detect link connectivity through auto-negotiation at the physical layer based on the physical connection status.
However, such a link detection mechanism has limitations. In some cases, it cannot provide users with reliable link detection information. For example, when the Tx and Rx ends of an optical cable are incorrectly connected to an optical port, due to the configured optical fiber converter, the link on the port is still physically Up, but the Layer 2 link is Down. Here is another example. An intermediate network exists between two Ethernet devices and a relay device is deployed on the network. The same problem will occur if the relay device fails.
With RLDP, the switch can easily and quickly detect link failures, including unidirectional, bidirectional, and loop link failures.
237
Are 10GE SFP+ ports of this series backward compatible?
Yes, 10GE optical ports of this series are backward compatible with 1GE optical modules.
234
Do RG-CS83 series switches support dual power supplies?
The switch has a single built-in power module and does not support dual power supplies.
236
加载失败
TOP
