Home> Ürünler> Anahtarlar> Access Switches>
RG-S2910C-24GT2XS-HP-E
Power Redundancy Support
Daha fazla+
Diverse ports
Secure and Reliable Hardware
and Software
Strict component selection
3-month reliability testing
Accurate traffic statistics
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
RG-S2910-10GT2SFP-P-E
RG-S2910C-48GT2XS-HP-E
24 10/100/1000BASE-T ports
48 10/100/1000BASE-T ports
10 10/100/1000BASE-T ports
Expansion Slots
Modular Power Slots
Fan Slots
Fixed
Fixed
Fixed
Fixed
M2910-01XS
M2910-01XT
M2910-04XSÛ
M2910-01XS
M2910-01XT
M2910-04XSÛ
Management Ports
1 USB 2.0 port
1 USB 2.0 port
264Gbps
264Gbps
256Gbps
264Gbps
264Gbps
96Mpps
132Mpps
18Mpps
96Mpps
132Mpps
Max. Number of 10GE Ports
RAM
512MB
16K
Routing Table Size
(IPv4/IPv6)
64 (IPv4/IPv6)
In: 1,500
Out: 500
In: 1,500
Out: 500
In: 750
Out: N/A
In: 1,500
Out: 500
In: 1,500
Out: 500
128
OpenFlow 1.0 & 1.3
IPv4 Routing Protocols
Hot Patch
Smart Power Supply
(W x D x H)  (mm)
440 × 260 × 43.6
440 × 260 × 43.6
340 × 260 × 44
440 × 320 × 44
440 × 360 × 44
≤3.5kg
≤4kg
<2.5kg
5.8kg (gross weight)
6.8kg (gross weight)
MTBF (hours)
Common Mode 6KV
Frequency: 50/60Hz
Rated current: 1.5A
Frequency: 50/60Hz
Rated current: 1.5A
Frequency: 50/60Hz
Rated current: 2A
AC power (RG-M5000E-AC500P):
Frequency: 50/60Hz
DC power (RG-M5000E-DC500P):
Rated current: 16.5A
AC power (RG-RG-PA1150P-F):
Frequency: 50/60Hz
Rated current: 10A
Rated current range: 10A
Frequency: 50/60Hz
Frequency: 50/60Hz
Rated current: 10A
24W
50W
850W (with 24-port PoE+)
1700W (with 48-port PoE+)
PoE Power
125W
RG-M5000E-AC500P: 370W
RG-M5000E-DC500P: 370W
RG-PA1150P-F: 740W
RG-PA1150P-F: 740W
IEC 60950-1, EN 60950-1
Emission Standards
Storage humidity: 5% to 95%RH
 *Future release support
RG-S2910-24GT4XS-E
RG-S2910-48GT4XS-E
Optional Accessories
M2910-01XS
M2910-01XT
M2910-02XS
*M2910-02XT
* Planned for future support
*M2910-04XS
RG-M5000E-DC500P
Flexible Port Types and
On-Demand Expansion
Multi-Process and Modular
OS RGOS 11.X
Optimal Quality
Stable Device Running,
PoE models, On-Demand Service
Management and Control
VSU Technology
Easy management:
Millisecond failover:
Exceptional scalability:
Fans with Multi-level Smart
Speed Adjustment
Always Seeking Ways to Boost
Optimization
PoC Guide
