RG-S7810C-X Anahtarlar - 1
RG-S7810C-X Anahtarlar - 2
RG-S7810C-X Anahtarlar - 3
RG-S7810C-X Anahtarlar - 4
8 x line card slots
M7800C-8SFG-XB
  • 8 GE SFG ports
M7800C-8SFX-XB
1+1
Supervisor Engine Redundancy
N+M
Power Supply Redundancy
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
1+1
RG-S7805C
RG-S7808C
RG-S7810C-X
Supervisor module slot
Line card slot
Switch fabric module slot
6 Tbps
12 Tbps
19.2 Tbps
4500 Mpps
9000 Mpps
14300 Mpps
● M7800C-8SFX-XB: 256000
● M7800C-8SFG-XB: 256000
● XA card: 96000
● XB card: 256000
● M7800C-8SFX-XB: 9600
● M7800C-8SFG-XB: 9600
● XA card: 4000
● XB card: 9600
● M7800C-8SFX-XB: 350000 (shared with IPv4 routes)
● M7800C-8SFG-XB:350000 (shared with IPv4 routes)
● XA card:64000 (shared with IPv4 routes)
● XB card: 350000 (shared with IPv4 routes)
4000
● M7800C-8SFX-XB: 65000 (shared with IPv4 routes)
● M7800C-8SFG-XB:15000 (shared with IPv4 routes)
● XA card: 65000 (shared with IPv4 routes)
● XB card: 65000 (shared with IPv4 routes)
2000
● Ingress
M7800C-8SFX-XB: 2800
M7800C-8SFG-XB: 2800
XA card: 7000
XB card: 2800
● Egress
M7800C-8SFX-XB: 4000
M7800C-8SFG-XB: 4000
XA card: 1500
XB card: 4000
442 mm × 451 mm × 175 mm (17.40 in. x 17.76 in. x 6.89 in.)
442 mm × 465 mm × 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.)
442.5 mm × 560 mm × 442 mm (17.42 in. x 22.05 in. x 17.40 in.)
32.35 kg
35.6 kg
43.55 kg
Rack Size
4 RU
10 RU
10 RU
2.2 GHz quad-core processor
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Flash Memory:8 GB
SDRAM:DDR4 4 GB
Max. Output Power
● RG-PA300I-F:
90 V AC to 180 V AC; Power: 300 W
180 V AC to 264 V AC; Power: 300 W
● RG-PA460I-F:
90 V AC to 180 V AC; Power: 460 W
180 V AC to 264 V AC; Power: 460 W
● RG-PA1000I-F:
90 V AC to 176 V AC; Power: 800 W
176 V AC to 264 V AC; Power: 1000 W
● RG-PA600I-F:
90 V AC to 180 V AC; Power: 600 W
180 V AC to 264 V AC; Power: 600 W
● RG-PA1600I-F:
90 V AC to 180 V AC; Power: 1200 W
180 V AC to 264 V AC; Power: 1600 W
● RG-PA1600I:
● RG-PA600I:
● RG-PD600I:
–40 V DC to –75 V DC; Power: 600 W
● RG-PA1600I-PL:
90 V AC to 176 V AC; Power: 1200 W
176 V AC to 264 V AC; Power: 1600 W
● M7805C-CM-X:< 40 W
● M7800C-12CQ-XB:< 240 W
● M7800C-24GT8SFP8XS-XA:< 95 W
● M7800C-32XS-XA:< 149 W
● M7800C-48XT-P-XB:< 300 W
● M7800C-48GT4XS-XA:< 85 W
● M7800C-48SFP4XS-XA:< 117 W
● M7800C-52XS-XB:< 250 W
● M7800C-8SFG-XB:< 250 W
● M7800C-8SFX-XB:< 250 W
● M7808C-CM-X:< 62 W
● M7810C-CM-X:< 60 W
● M7810C-FE-X I:< 50 W
● M7810C-FE-X II:< 160 W
● Supervisor module: air intake from the right and exhaust from back
● Service module: air intake from the right and exhaust from back
● System power module: drawing air outward with built-in fans, air intake from the front panel and exhaust from back
● Supervisor module /Service module: air intake from the right and exhaust from back, drawing air outward to form convection for heat dissipation
● System power module: air intake from the front panel and exhaust from back, drawing air inward to form convection for heat dissipation
● Line card: air intake from the side and exhaust from back
● Supervisor module/Switch fabric module: air intake from the front panel and exhaust from back
5% to 95% RH
–500 m to +5000 m (–1,640.41 ft. to +16,404.20 ft.)
Surge Protection of Communication Ports
6 kV
RG-S7805C
RG-S7808C
RG-S7810C-X
IP subnet-based VLAN
protocol-based VLAN
Super-VLAN
STP (IEEE 802.1.d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
OpenFlow 1.3
DHCPv6 client
DHCPv6 relay
FTP Server
FTP Client
NTP server
NTP Client
SNTP Client
TFTP Client
TFTP Server
BGP4
BGP4+
IS-ISv4
IS-ISv6
OSPFv3
RIP
RIPng
Routing Policy
Policy-based routing (PBR)
PIM-DM
PIM-SM
MLD v1/v2 snooping
MPLS 6VPE
MPLS IPv6
MPLS forwarding
LDP
LSP
VXLAN Layer 2 bridge
VXLAN Layer 3 gateway
Standard IP ACL
extended IP ACL
extended MAC ACL
Layer 2 and Layer 3 port ACL
VLAN ACL
Expert-level ACL
Applying ACLs globally
ACL COUNTER
ACL LOGGING
ACL REMARK
802.1P
SP
WRR
SP+WFR
RED/WRED
MPLS QOS
1+1 fan redundancy
VRRP+
Faulty optical port isolation
port security
802.1X authentication
RADIUS
TACACS+ login authentication
SSHv2
IPv6 SAVI
SNMP V1/V2c/V3
RMON
GRPC
SPAN
ERSPAN
VLAN mirroring
Web-based NMS
Energy-Saving Design
RG-S7810C-X
RG-S7810C-X switch, which can accommodate eight line cards, two supervisor modules, and four switch fabric modules
S7808C
RG-S7808C switch, which can accommodate six line cards and two supervisor modules. When the M7808C-CM-X supervisor module is used, you can select line cards of the RG-S7800C-X series.
S7805C
RG-S7805C switch, which can accommodate six line cards and two supervisor modules. When the M7805C-CM-X supervisor module is used, you can select line cards of the RG-S7800C-X series.
M7810C-CM-X
M7805C-CM-X
M7808C-CM-X
Notes:
Power Modules and Fan Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1000I-F
S7805C Power module (support redundancy, AC, 1000W,10 A)
RG-PA1600I-F
RG-PA1600I-PL
Common PoE power module (available for redundancy, AC, 1600 W, 16 A)
RG-PA600I
S7810C-X power module (available for redundancy, AC, 600 W, 10 A)
RG-PD600I
RG-PA1600I
S7810C-X power module (available for redundancy, AC, 1600 W, 16 A)
M78-PSE-X
Common PoE power chassis, used together with RG-PA1600I-PL
Switch Fabric Modules
M7810C-FE-X I
M7810C-FE-X II
M7800C-32XS-XA
M7800C-48GT4XS-XA
M7800C-48SFP4XS-XA
M7800C-52XS-XB
M7800C-12CQ-XB
M7800C-48XT-P-XB
48 x 100M/GE/2.5GE/5GE/10GE electrical ports (RJ45 and PoE/PoE+)
M7800C-8SFG-XB
CWDM line card for RG-S7800C-X series switches, supporting eight SFG GE ports
M7800C-8SFX-XB
CWDM line card for RG-S7800C-X series core switches, supporting eight SFX 10GE ports with each port backward compatible with the Gigabit rate
