12 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS-P24 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-24GT4XS24 x GE Electrical Ports, 4 x 10GE SFP+ Ports
RG-CS83-48GT4XS-P48 x GE Electrical Ports, 4 x 10GE SFP+ Ports,PoE+
RG-CS83-48GT4XS48 x GE Electrical Ports, 4 x 10GE SFP+ Ports
RG-CS83-12GT4XS-P |
RG-CS83-24GT4XS |
RG-CS83-48GT4XS |
RG-CS83-24GT4XS-P |
RG-CS83-48GT4XS-P |
Fixed ports |
12 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
24 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports |
48 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports |
24 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
48 x 100M/1000M BASE-T ports 4 x 1GE/10GE SFP+ ports support PoE+ |
Fan module |
1 x fixed fan module |
No fan |
Power module |
1 x fixed power module |
Fixed management port |
1 x console, and 1 x USB 2.0 port |
Packet forwarding rate |
78 Mpps |
96 Mpps |
132 Mpps |
96 Mpps |
132 Mpps |
Switching capacity |
104 Gbps |
128 Gbps |
176 Gbps |
128 Gbps |
176 Gbps |
MAC address table size |
16,000 |
4,000 |
4,000 |
4,000 |
4,000 |
4,000 |
6,000 |
1,000 |
2,000 |
750 |
Ingress: 1,750 Egress: 800 |
Number of VSU members |
4 |
4 |
4 |
4 |
4 |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3 kg (6.61 lbs) |
3.75 kg (8.27 lbs) |
1.0 GHz dual-core CPU |
Flash memory |
512 MB |
512 MB |
512 MB |
512 MB |
512 MB |
BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
16 MB |
SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
1 GB |
Data packet buffer |
4 MB |
4 MB |
4 MB |
4 MB |
4 MB |
Power and Consumption |
< 35 W (non-PoE) < 405 W (PoE full load) |
< 25 W |
< 40 W |
< 52 W (non-PoE) < 460 W (PoE full load) |
Maximum output power |
409 W Maximum PoE output :370W |
25 W |
40 W |
460 W Maximum PoE output :405W |
Rated input voltage |
100 V AC to 240 V AC |
24.14 years |
23.74 years |
23.85 years |
23.94 years |
22.86 years |
Primary airflow |
0°C to 45°C (32°F to 113°F) |
Operating noise |
27℃: < 35 dB |
< 20 dB |
27℃: < 32 dB |
27℃: < 35 dB |
27℃: < 35 dB |
Interface surge protection |
Power port: 6 kV(common mode)/8 kV (differential mode) Communication port: 10 kV |
Power port: 6 kV(common mode)/6 kV (differential mode) Communication port: 10 kV |
Coating Conformal |
Conformal coating supported (key components only) |
RG-CS83 Series |
Feature |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4K VLANs) |
Super-VLAN and private VLAN |
Basic QinQ Selective QinQ |
STP, RSTP, and MSTP |
IP service |
ARP |
DHCP snooping |
DHCPv6 snooping |
IP routing |
OSPFv2 and OSPFv3 |
IPv4 and IPv6 VRF |
IPv4 and IPv6 PBR |
IGMP v1/v2 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
MSDP |
MLD v1/v2 |
MLD snooping v1/v2 |
PIM-SMv6 and PIM-SSM v6 |
Multiple AAA modes |
RADIUS and TACAS+ |
Interface-based and MAC address-based 802.1x authentication |
HTTPS |
SSHv1 and SSHv2 |
Global IP-MAC binding |
SAVI |
REUP, RLDP, DLDP |
BFD |
SPAN, RSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/v3 |
RMON (1, 2, 3, 9) |
NETCONF |
CWMP (TR-069) |
Cloud and SON |
RG-CS83-12GT4XS-P, RG-CS83-24GT4XS-P, and RG-CS83-48GT4XS-P: IEEE 802.3af and 802.3at Warm start Interface priority |
RG-CS83-12GT4XS-P |
12 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module |
RG-CS83-24GT4XS |
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module |
RG-CS83-48GT4XS |
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module |
RG-CS83-24GT4XS-P |
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module |
RG-CS83-48GT4XS-P |
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 405 W PoE output, and built-in power module |
MINI-GBIC-ZX50-SM1550 |
MINI-GBIC-ZX100-SM1550 |
10GE LC module (62.5/125 μm: 33 m (108.27 ft.); 50/125 μm: 66 m (216.54 ft.); transmit for 300 m (984.25 ft.) when modal bandwidth is 2000 MHz * km), applicable to SFP+ ports |
10GE SFP+ fiber-optic cable, 1 m (3.28 ft.), including one cable and two interface modules |
10GE SFP+ fiber-optic cable, 3 m (3.28 ft.), including one cable and two interface modules |
10GE SFP+ fiber-optic cable, 5 m (3.28 ft.), including one cable and two interface modules |
