They are highlighted by their high performance, high density, and the data speed of up to 25 Gbps/100 Gbps. They meet the Spine-Leaf network architecture design requirements.
four service slots, 25GE/40GE/100GE line cards
RG-S6510-48VS8CQNumber of IPv4/IPv6 host routing entries: 128K/64K
RG-S6510-32CQ32×100G ports
RG-S6510-48VS8CQ |
RG-S6510-32CQ |
Ports |
48 x 25GE SFP28 ports and 8 × 100GE QSFP28 ports |
32 x 100GE QSFP28 ports |
Expansion Module Slots |
Two power module slots, supporting 1+1 redundancy Four fan module slots, supporting 3+1 redundancy |
Two power module slots, supporting 1+1 redundancy Five fan module slots, supporting 4+1 redundancy |
Management Port |
Switching Capacity |
4.0Tbps |
6.4 Tbps |
Packet Forwarding Rate |
2000 Mpps |
2030 Mpps |
802.1Q VLAN |
4094 |
Dimensions (W × D × H) |
442 mm x 387 mm x 44 mm (17.40 in. x 15.24 in. x 1.73 in., 1 RU) |
442 mm x 560 mm x 44 mm (17.40 in. x 22.05 in. x 1.73 in., 1 RU) |
About 8.2 kg (18.08 lbs, including two power supply modules and four fan modules) |
About 11.43 kg (25.20 lbs, including two power supply modules and five fan modules) |
AC |
● Rated voltage: 110 V AC/220 V AC ● Rated voltage range: 100 V AC to 240 V AC (50 Hz to 60 Hz) ● Max voltage range: 90 V AC to 264 V AC (47 Hz to 63 Hz) ● Rated input current range: 3.5 A to 7.2 A |
High-voltage DC |
Input voltage range: 192 V DC to 288 V DC Input current: 3.6 A |
Low-voltage DC |
● Input voltage range: –36 V DC to –72 V DC ● Rated input voltage: –48 V DC ● Rated input current: 23 A |
N/A |
Maximum Power Consumption |
● Max: 300 W ● Typical: 172 W ● Static: 98 W |
● Max: 450 W ● Typical: 270 W ● Static: 150 W |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
0°C to 40°C (32ºF to 104ºF) |
Operating Humidity |
10%RH to 90% RH (Non-condensing) |
Working altitude |
Operating altitude: up to 5000 m (16,404.20 ft.) |
Software Specifications |
RG-S6510-48VS8CQ |
RG-S6510-32CQ |
L2 Protocols |
IEEE802.3ad (Link Aggregation Control Protocol), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, MLD Snooping, Jumbo Frame (9 KB), IEEE802.1ad (QinQ and Selective QinQ), GVRP |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
IGMPv1, v2, v3、IGMP Host Behavior、Member Query and Response、Querier Election、IGMP Proxy、Multicast Static Routing、MSDP、PIM-DM、PIM-SM、PIM-SSM、Enabling PIM on Layer-3 Subinterface、PIM-SMv6、MLD v1 and v2、MLD Proxy、Enabling PIMv6 on Layer-3 Subinterface |
ACL |
Standard IP-based ACL、Extended MAC/IP-based ACL、Expert-level ACL、ACL 80、IPv6 ACL、ACL Logging、ACL Counter (Ingress and egress counters are supported in interface or global configuration modes)、ACL Re-marking、Global ACL、ACL-based Redirection、Displaying ACL Resources、Processing First Packet of TCP Handshake When Binding the ACL to Restrict SIP、Matching Against 5-Tuple of Pass-by VXLAN Inner IP Packets、The expert-level ACL supports matching the IP flag and DSCP fields of VXLAN inner packets、Ingress/Egress ACLs |
When the same ACL is applied to different physical interfaces or SVIs, resources can be multiplexed |
N/A |
Data Center Features |
VXLAN routing and VXLAN bridging IPv6 VXLAN over IPv4 and EVPN VXLAN PFC, ECN, and RDMA M-LAG *RoCE over VxLAN OpenFlow 1.3 |
Visualization |
gRPC sFLOW sampling INT |
QoS |
Virtualization |
Virtual Switching Unit |
Buffer Management |
Buffer status monitoring and management, and identification of burst traffic |
HA Design |
Security Features |
Management Mode |
SNMP v1/v2c/v3, Netconf, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP clock, Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, Python, fan and power alarm, and temperature alarm |
Other Protocols |
Specification |
RG-S6510-48VS8CQ |
RG-S6510-32CQ |
Safety |
● IEC 62368-1 ● EN 62368-1 ● NM EN 62368-1 ● NM CEI 62368-1 ● EN IEC 62368-1 ● BS EN IEC 62368-1 ● UL 62368-1 ● CSA C22.2#62368-1 ● GB 4943.1 |
● IEC 62368-1 ● EN 62368-1 ● EN IEC 62368-1 ● UL 62368-1 ● CAS C22.2#62368-1 ● GB 4943.1 |
● EN 55032 ● EN 55035 ● EN IEC 61000-3-2 ● EN IEC 61000-3-3 ● EN 61000-3-3 ● EN 300 386 ● ETSI EN 300 386 ● NM EN 55035 ● NM EN CEI61000-3-2 ● NM EN 61000-3-3 ● CNS 13438 ● ICES-003 Issue 7 ● ANSI C63.4-2014 ● FCC CFR Title 47, Part 15, Subpart B ● ANSI C63.4-2014 ● VCCI-CLSPR 32 ● GB/T 9254.1 |
● EN 55032 ● EN 55035 ● EN 61000-3-2 ● EN 61000-3-3 ● EN IEC 61000-3-3 ● EN IEC 61000-3-2 ● EN 300 386 ● ETSI EN 300 386 ● CES-003 Issue 7 ● ANSI C63.4-2014 ● FCC CFR Title 47, Part 15,Subpart B ● VCCI-CISPR 32 ● GB/T 9254.1 |
Environment |
Product Model |
RG-S6510-48VS8CQ |
48 × 25GE ports and 8 × 100GE ports. |
RG-S6510-32CQ |
Provides 32 × 100G ports. |
Product Model |
RG-PA550I-F |
550 W power supply module (AC and 240 V HVDC) |
RG-PD800I-F |
800 W power supply module (48 V LVDC), applicable only to RG-S6510-48VS8CQ |
M6510-FAN-F |
Fan module of RG-S6510-48VS8CQ, supporting 3+1 redundancy, hot swapping, and front-to-rear ventilation design. |
M1HFAN I-F |
Fan module of RG-S6510-32CQ, supporting 4+1 redundancy, hot swapping, and front-to-rear ventilation design. |
Product Model |
100G-QSFP-SR-MM850 |
100G-QSFP-LR4-SM1310 |
100G-QSFP-iLR4-SM1310 |
100G-QSFP-ER4-SM1310 |
100G-AOC-10M |
100G-AOC-5M |
Product Model |
40G-QSFP-SR-MM850 |
40G-QSFP-LR4-SM1310 |
40G-QSFP-LSR-MM850 |
40G-QSFP-iLR4-SM1310 |
40G-QSFP-LX4-SM1310 |
40G-AOC-30M |
40G-AOC-5M |
Product Model |
VG-SFP-AOC5M |
VG-SFP-LR-SM1310 |
VG-SFP-SR-MM850 |
25G SR module, SFP28 form factor, Duplex LC, 850 nm, 100 m (328.08 ft.) over MMF |
Product Model |
XG-LR-SM1310 |
XG-SR-MM850 |
XG-SFP-ZR-SM1550 |
Product Model |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
Product Model |
Mini-GBIC-GT(F) |
