RG-S6510-48VS8CQ Anahtarlar - 1
RG-S6510-48VS8CQ Anahtarlar - 2
RG-S6510-48VS8CQ Anahtarlar - 3
RG-S6510-48VS8CQ Anahtarlar - 4
RG-S6510-48VS8CQ Anahtarlar - 5
RG-S6510-48VS8CQ Anahtarlar - 6
RG-S6510-48VS8CQ Anahtarlar - 7
RG-S6510-48VS8CQ Anahtarlar - 8
RG-S6510-48VS8CQ Anahtarlar - 9
RG-S6510-48VS8CQ Anahtarlar - 10
RG-S6510-48VS8CQ Anahtarlar - 11
RG-S6510-48VS8CQ 25GE Data Center Access Switch
RDMA-capable high-density 25GE/100GE access switch for data center networks with low latency and no packet drop
  • 48 x 25GE SFP28 ports + 8 x 100GE QSFP28 ports, and 32 MB buffer, easily coping with burst traffic
  • Multiple hardware-level protection, ensuring service consistency and network stability
25GE Data Center Access Switch RG-S6510-48VS8CQ
8 x 25GE SFP28 ports and 8 x 100GE QSFP28 ports, delivering line-rate forwarding capacity
De-stacking
M-LAG
RG-S6510-48VS8CQ
RG-S6510-32CQ
32 x 100GE QSFP28 ports
Expansion Module Slots
4.0Tbps
6.4 Tbps
2000 Mpps
2030 Mpps
4094
(W × D × H)
AC
High-voltage DC
Input current: 3.6 A
Low-voltage DC
● Rated input current: 23 A
Maximum Power Consumption
● Max: 300 W
● Typical: 172 W
● Static: 98 W
● Max: 450 W
● Typical: 270 W
● Static: 150 W
0°C to 40°C (32ºF to 104ºF)
Working altitude
RG-S6510-48VS8CQ
RG-S6510-32CQ
L2 Protocols
L3 Protocols (IPv4)
IPv6 Basic Protocols
Data Center Features
PFC, ECN, and RDMA
M-LAG
*RoCE over VxLAN
OpenFlow 1.3
sFLOW sampling
INT
Virtualization
Virtual Switching Unit
Buffer Management
HA Design
Security Features
Management Mode
Specification
RG-S6510-48VS8CQ
RG-S6510-32CQ
● NM EN 62368-1
● NM CEI 62368-1
● EN IEC 62368-1
● BS EN IEC 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● EN IEC 62368-1
● UL 62368-1
● CAS C22.2#62368-1
● EN IEC 61000-3-3
● EN 300 386
● ETSI EN 300 386
● NM EN 55035
● NM EN CEI61000-3-2
● NM EN 61000-3-3
● CNS 13438
● ICES-003 Issue 7
● ANSI C63.4-2014
● ANSI C63.4-2014
● VCCI-CLSPR 32
● EN 61000-3-2
● EN IEC 61000-3-3
● EN 300 386
● ETSI EN 300 386
● CES-003 Issue 7
● ANSI C63.4-2014
● VCCI-CISPR 32
    RG-S6510-48VS8CQ
    RG-S6510-32CQ
    Provides 32 × 100G ports.
    Fan and Power Supply Modules
    RG-PA550I-F
    RG-PD800I-F
    M6510-FAN-F
    M1HFAN I-F
    XG-LR-SM1310
    XG-SR-MM850
    Mini-GBIC-GT(F)
